COMPREHENSIVE VGA15P-P-6HR - A 6 FT. VGA WITH AUDIO HD15 CABLE
Comprehensive VGA15P-P-6HR/A 6 ft. VGA with Audio HD15 Cable Type: VGA Cables Type: VGA Cables Color: Black Connector Number: 2 Connector Detail: Connector Type 1: HD15 Male with stereo 3.5mm Audio Male Connector Type 2: HD15 Male with stereo 3.5mm Audio Male Terminal Gender: Male to Male Specifications: Performance Grade: Better Resolution: SVGA through QXGA (2048x1536) Gauge: 26AWG Center Conductor: Tinned Copper Connector Finish: Nickel Attenuation @100MHz at 100ft: 5.460dB Attenuation @400MHz at 100ft: 11.109dB Attenuation @1000MHz at 100ft: 19.423dB UL Rated: Yes Ferrite Cores: No RoHS Compliant: Yes Jacket Type: Xtra-Flex PVC Temperature Rating: 80 deg C Voltage: 30V Shielding: Triple Shielded, Inner Bare Copper Wrap, Outer 100% Aluminum Mylar Wrap, 95% Braid
Price: 22.17
