COMPREHENSIVE VGA15P-P-50HR - A 50 FT. HD15 VGA CABLE WITH AUDIO
Comprehensive VGA15P-P-50HR/A 50 ft. HD15 VGA Cable with Audio Type: VGA Cables Type: VGA Cables Color: Black Connector Number: 2 Connector Detail: Connector Type 1: HD15 Male with stereo 3.5mm Audio Male Connector Type 2: HD15 Male with stereo 3.5mm Audio Male Terminal Gender: Male to Male Specifications: Performance Grade: Better Resolution: SVGA through QXGA (2048x1536) Gauge: 26AWG Center Conductor: Tinned Copper Connector Finish: Nickel Shielding: Triple Shielded, Inner Bare Copper Wrap, Outer 100% Aluminum Mylar Wrap, 95% Braid Attenuation @100MHz at 100ft: 5.460dB Attenuation @400MHz at 100ft: 11.109dB Attenuation @1000MHz at 100ft: 19.423dB UL Rated: Yes Ferrite Cores: No RoHS Compliant: Yes Jacket Type: Xtra-Flex PVC Temperature Rating: 80 deg C Voltage: 30V
Price: 57.74
