COMPREHENSIVE VGA15P-P-100HR - A 100 FT. HR PRO SERIES VGA W - AUDIO HD15 PIN PLUG TO PLUG CABLE 100FT
Comprehensive VGA15P-P-100HR/A 100 ft. HR Pro Series VGA w/Audio HD15 Pin Plug to Plug Cable 100ft Type: VGA Cables Color: Black Connector Detail: Connector Type 1: HD15 Male with stereo 3.5mm Audio Male Connector Type 2: HD15 Male with stereo 3.5mm Audio Male Specifications: Performance Grade: Better Resolution: SVGA through QXGA (2048x1536) Connector Finish: Nickel Attenuation @100MHz at 100ft: 5.460dB Attenuation @400MHz at 100ft: 11.109dB Attenuation @1000MHz at 100ft: 19.423dB Ferrite Cores: No Temperature Rating: 80 deg C Voltage: 30V Weight Lbs: 12.7 Shielding: Triple Shielded, Inner Bare Copper Wrap, Outer 100% Aluminum Mylar Wrap, 95% Braid Conductor: Tinned Copper
Price: 102.20
